98-EX-Leather
My gas and temperature needles do not read accurate.
They vary and either one work temporary and vice versa. Sometimes both needles just drop below E for gas and C for the temperature.
My questions are:
- is there something wrong with the cluster? Can i purchase a replacement and it will fix this problem? Will the milage be accurate if i install a new cluster?
- is this a sensor issue? One at the fuel pump end and the other in the temperature end? If so, are these simple fixes?
Thank you in advance for the help.
Sent from my SM-N910P using Tapatalk
My questions are:
