I've got a 2000 LX I4 sedan with the BAXA automatic in it. I've read in many places that the differential bearings (some people are calling carrier bearings) are the real common failure that these automatics have (that then leads to other problems as they fail).
To test the bearing, I've heard that I should just check for play by pushing the passenger axle up and down near the transmission, but how much play (if any) is considered normal? There is some play in the bearing but it's very little currently.
We were told by a local dealership that the transmission needed to be replaced, but it seems that one of the solenoids wasn't functioning properly, so I replaced it, and it is shifting some better. However, in changing the fluid, I did notice some (not a lot) of metal particles on the drain plug magnet.
Is this normal for these transmissions to have some metal particles on the magnet, or does having any at all point to an impending bearing failure?
