Mike's_Taffeta
Victorville, Ca.
After reading through all of this and doing some research myself, I don't see why you coukldnt just swap the hubs instead of buying the knuckles/spindles. The only ****ty part is that they're press in but its nothing a 20 ton press can't handle, and you can put in new wheel bearings while you're at it.
based in: not shared
no one said you couldnt. people with lx's need to swap out at least the rear knuckles, since they're different between lx and ex. personally, id rather swap out all the knuckles to make it easier and so I could replace the bearings easily.
CHID0
Boston
Are the caliper brackets on the knuckles and spindles different on the 4 banger vs the v6? I'm considering just swapping the hubs. You can get fresh hubs (rear as far as i know) for about 85 a pop with bearings and studs. Not sure about the front though....
Mike's_Taffeta
Victorville, Ca.
Fronts are about 45 a piece.
yeah, i think the v6 rears and the i4 disc rears are the same, and the fronts are all the same front knucle, because i could just swap my front hubs out with the v6 ones, and everything will fit fine.
FunnyVictor86
California
if you have disc's in i4 all you need is rear hub and disc from a v6 ... as far as the front i can't say for sure because i bought it complete with the knuckles ... but part numbers for the knuckles on v6 and i4 are the same at HondaAutomotiveParts.com aka majestic honda
