Russianred
Snail Spools You!
^ haha true.
There isn't an actual step by step process on the site, most people use this as a guide and fill in the holes themselves. And many have done it successfully.
The reason why I asked is because I'm scared to just go in and do it then fudge something up and regret it later :/. Its either this or adapters from a well known company.All I did when I started on this project was look at parts diagrams and compare it to what I already knew from my car. It was literally just figuring out how it all went together in my head.
I could make a step by step but it'd be so lengthy and involved that it's much easier to give someone the basics and let them figure the rest out for themselves. No one showed me how to do it, I just got my hands dirty. Sometimes that's the best way to learn.
Definitely go with the swap over adapters.
Understandable, but when you think about it a car is just nuts and bolts. You're not doing something like replacing/adjusting timing parts, rebuilding a transmission, or adjusting your valves. The bearings are already pressed in if you get complete hubs, all you have to do is remove and replace parts. The hardest thing you'll probably face is seized nuts/bolts. Maybe running the e-brake cables, I don't know.
Take a weekend and do one corner so you don't overwhelm yourself...prep Friday night, and get an early start on Saturday morning. Take pictures of stuff before you take it apart so you know how to put it back together, and make sure you have all the tools/tricks necessary to do the job. If you're that worried about it, have a plan B in case somehow you render the car undriveable come Monday (which I doubt).
