Ok, my '98 coupe (4 cyl) starting overheating 2 weeks ago. When I pop open my hood after it overheating, it is wet right around where the bottom radiator hose hooks up to the thermostat. I change the hose first. Works fine for 2 days, and overheats in city driving. I then test the fan relay, and it works. Next I replace the thermostat with the factory OEM part (180 F, not the 170 F thermostat). I run my car with A/C on, hood open to observe. After about 15 min., fan comes on. SO..I assume that's working fine. This replaced thermostat gives me 2 days of good driving, and overheats again in city driving. Oh ya, let me also add that after all changes, I drain and refill the coolant and bleed air, and there is no "milky" sign of coolant in the engine oil. Please, if you have any other ideas...
