HondaLuver83
Since its intermittent, I would lean towards a small electrical problem
yea i had the same problem, but it turned out to be my security system/alarm. im not sure if u have one, but once mine was disabled and unplugged, m car was fine afterwards. cuz after awhile this problem would happen to me periodically until my car wouldnt start anymore.
I had the same problem. It is likely to be the Ignition Switch which IS A RECALL so take your car to the dealer and get it fix for free. Eventually your car may shut off while driving.
Is this only when your car is outside on a hot day? I had a similar problem when I first got my EX. It was only on hot days when I parked the car out in the sun all day. It would crank and crank but not turn over. Once the sun went down and things started cooling off, it would start right up. Try rolling down your windows and opening up the sunroof (if you have one). Let the car cool off for a bit then try cranking it. I forget wtf my problem was tho, my dad ended up bringing it to work one day and the techs fixed it. This was a few years ago when I didnt know much about cars. I'll look around for a receipt or something and see if I can tell you what it was.....
you know i had this problem awhile back, either its your idle sensor or your throttle cable was kinda loose, my problem was my idle sensor it'll start up but once it did it just died when i replaced that everything was fine
