**Feeler** Battery Relocation DIY (to trunk)
Status
Not open for further replies.
hancockd
SLO CG2
Orlando, FL
I would like to see this as well even tho I have a v6.... just kinda curious on how you ran it and the "personal" things that you did.... Seeing some peoples ingenuity/creativity is intriguing.....while others is just....uh.... yea....
AFAccord
Spangdahlem, Germany
Well there are probably a hundred different combinations of how to mount the box, whether to use a box, remove the tray to make room or just cut it. what do do with the carpet, which side to run the cable on, whether to run it inside or outside, what type of fuse to use, fuse box, where to connect the box, to use an emergency cut off switch or not, where to mount it, power or ground, all sorts of crap. So, I guess I'll just share my experience with it all.
I'll write it up tonight in a separate thread, and this one can then be deleted.
IcyAccord
er.. ran it underneath? That's not smart, but whatever floats your boat.
IcyAccord
I guess I'll post pictures of mine then.
CHID0
Boston
Go for it....been thinkin about doing it too but not for a while.
Status
