Fuel Pump Relay
Snoobly
Iowa
Can anyone tell me exactly where the Fuel Pump Relay is located? I know it's under the driver's side dash, behind the fuses right?? Which one? There are like three of them there.
Thanks!!
Snoobly
Iowa
same thing?? hmm. I have no fuel pump prime, but the engine cranks over and won't start. Sound like the main relay?
I put the stock fuel pump back in and it still didn't work, and i doubt that my 9 month old walbero 255 and the stocky are both bad.
Any ideas?
kn0x47
Senior Member
Birmingham, AL
tap the main relay while you try to crank it and see if it starts. could have you flooded the motor? that can cause the fuel pump not to prime
001Stunna
Toronto, ON CANADA
The main relay should click when you turn the key to second position. If it does not click you should look into replacing it or possibly needing to remelt and add solder to the joints.
Snoobly
Iowa
figured it out. Thanks guys. It was some ACG fuse under the hood. I didn't think to check the ones under the hood until later. lol
