Sl1m_Shady
Alright so within the past week, ive noticed my 01 Ex 4cyl sedan has started to leak a minimal amount of this weird mixture of gasoline/oil.
I would assume by the looks of the spots on the ground its no more than a few drops. At first i thought it was leaking antifreeze but i touched/smelled the stuff and its not. I tried to locate where it was coming from, but i only found one small thing:
The air flow tube running from my cold air intake to my valve cover gasket had some residue around the opening of the valve cover end. I took it off, there was a very small amount, no more than a drop of the stuff at the end of the hose. i took a circular clamp and put it around the tube/opening to the valve cover and it seemed that nothing else would be leaking out of there....
but obviously...
nothing but air should be in that tube in the first place, right?
Or would you guys have a different explanation for the leak???
any input would be appreciated...
Thanks
but obviously...
Thanks
