I bought mine off of Ebay, they were made by RActive. They're not up all the time, you just have to check the site periodically. The bezel that came with it did not fit because the holes for the dimmer and ODO reset were not big enough to fit over both switches. You would have to dremel these to expand the diameter of those two holes to make it fit. I didn't use it because mainly I have no other "brushed aluminum" in my cabin so it would look out of place. I only used the rings and think it looks pretty good.
Word to the wise...if you buy these be sure to carefully crimp the bottom middle of the speedometer ring (on the raised part), because the butt of the speedo needle will not be able to clear it when it's pointing at 80 and you will mess up the needle. It's not that big of a deal, basically my speedo needle doesn't move until I hit 10-12mph, and then it rotates really quickly to catch up and then it's fine and gives accurate readings. Just hadn't seen anyone else ever mention this, so thought I would tell you.
Good luck.
looks good...thanks for the tip ill make sure to do that
