2002CG3coupe
The oil lines to plug are on the cam side of the head I will take a pic of the ones to plug later after work. I have an h22 head that I'm going to use so it should be the same. I just laid the head gasket on the block and you can clearly tell which 2 lines need to be plugged cause of how off the two oil lines are.
This
You'll also need to press out the the sprocket gear in the waterpump from your f23 and use a h22 waterpump gear sprocket and h22 crankshaft sprocket in order for the timing belt to fit correctly
