RussianMenace
I was changing out a bulb in the clock and odometer of my 99 accord and had what looks seems to have been a short (yeah, I was a dummy and forgot to disconnect the battery). Started the car and noticed that other than the backlighting, the instrument panel was dead, no readouts no movement of the needles and I couldn't put it in gear.
Checked the driver-side fuse box and sure enough, 7.5A fuse for the instrument panel was blown. Swapped it out, dash came alive as it should. However, after a few seconds I realized that the engine and ABS lights stayed lit.
Did something else go? Any ideas where I can start to the search? Or does something need to be reset?
