Hard Jolt When Pressing on Gas after rolling stop
2002CG3coupe
Exit 13 - SSPkwy
It's been 4 years, started when my mom still owned it. I am my parents "mechanic". I've babied it for a year now. Mounts have been replaced and I've done drain and fills about 4 times since I took it off her hands last year. Hasn't gotten much worse but no better either. Every time I drive it I anticipate a flashing D4, but it just keeps going (knock on wood). Hopefully it goes out after I save enough for a 6speed swap.
OEM mounts or aftermarket oe style mounts...sometime aftermarket mounts lifespans varies, some good others no so.
spacemonkee23
Placentia, CA
All mounts were changed with OEM at the same time about 3 years ago. Originally that was my consensus but I only helped a little and damn were they expensive!
Depends on what mounts you buy. My poly mounts were about $320. But I'm guessing you'd want more of stock replacement, so either OEM, or OE. I've heard good things about Beck-Arnley. Whatever you do, don't buy Duralast or similar.
2002CG3coupe
Exit 13 - SSPkwy
Maybe a change of ATF, Redline D4 or Amsoil might help to reduce the harsh fiction between shifting in your A/T gearbox.
