they are screwed into the rear dash or whatever you wanna call it. you'll have to take off the panel covers on the C pillars, lower the rear seat and take off the trim behind it. then undo the clips inside of the trunk under where the rear speakers are that are holding the center brake light down and take that out. then undo the clips under there that are holding the rear dash down. then you should be able to take the rear dash out
