White6GAV6
I literally just did this like 30 minutes ago, except I used tape so it's easy to revert back to having them on. Should be a must for coupes. Looks great, pretty much doesn't cost anything, and takes 15 minutes max.
No i didn't take any pictures, but it's quite easy. I have the stock/factory bulb. All you have to do is pull the top bulb harness out, look to see where the red wire is positioned, determine which prong(guess that's what it's called? drew a blank), cover that up with a piece of electrical tape making sure it isn't covering any other one though. Plug the bulb back in and check to see if it works.
Let me know if that makes sense.
Once you open it up and look at it, it will all make sense. Hopefully haha
Remove the bulb for the turn signal. Put a small, thin piece of electrical tape over one of the metal contacts. Put the bulb back in. If it still lights up, remove bulb and place the tape on the other contact and put it back in. It should then NOT light up.
I'm also curious to find out how to run my high beam bulbs without my low beams being illuminated as well? I recently bought some yellow 9005 high beams and I've seen other Accords on here with that setup and just wanted to know how to get them to come on without the low beams on too. Thanks for any input.
