So we are over at church, go to start the car and... nothing.
Not the battery this time, fairly new, connections are good. Alternator is fairly new...
Symptoms:
Turning the key to run all the dash lights come on as normal.
Turning the key to start all the lights go out except for 3 idiot lights that are just flickering. No clicking from the start relay. I release the key.
There is a funny high pitched hissing sound (the sound a capacitor might make before it blows up) coming from the dash somewhere for a few seconds then the dash lights come back on with a click that seems to come from the steering column or speedo area.
Tried this a few times same result.
Turn the key over same thing once, then on the second time it fires right up like nothing is wrong.
I push fate and turn it off and use the wifes key (more worn) Dead as a doornail for 5-6 goes, not even the rapid clicking sound of an expired battery. Jiggle the key around and bingo it fires right up - voom.
Our 2000 is not supposed to have the ignition switch problem. Could this be the ignition switch (90%) or a bad ground (10%) or both or???
I'm putting the ground in here because I have seen other things like flickering lights with the wipers on, Ventilator fan speed dropping then coming back up, specially when slowing down.
I hate electrical problems.
Rich
Symptoms:
Rich
