LowerMyCG5
Kevin you know I'm in.
Maybe getting some caster arms for the front also?
I'll have to discuss it in more detail with my associates, but they will be designed right here in California, and then most likely manufactured in Korea. I don't know a ton of details quite yet, since the idea was proposed to me yesterday, but I will update this thread with all the relevant info.Im interested. Always down for quality parts. Who will be the manufacturer? Any info/review on their other products. How long would this take IF this acutally becomes a group buy and follows through?
With just these two arms per side, it shouldn't be too bad. They will know right away which arm is for camber and which one is for toe, and they should adjust easily as long as the tech is able to get under the car. I just had my car aligned on Saturday, and it only took the guy like 30-45 minutes to align my whole car, even accounting for adjusting the steering wheel, dialing in my camber, etc.Yeah, they would be very unhappy. I suggest finding a really good alignment guy, and a nice tip so they make sure your rear track is correct. You could potentially move the rear wheels in & out to get the fender gap perfect, you could also really **** it up.
I think it's a great idea, I just know your average tire shop isn't going to have a damn clue. Most of them only know 'get it in the green' and don't really know what they are adjusting at all. The software on the alignment machine is capable of showing the measurements needed, those pages usually used to check for accident damage, but most of those guys don't know how to get to them or read them.
Most of them are happy to get 1hr pay for a 4-wheel alignment. Getting everything straight with that many adjustments will be 1+ hours in just the back.
I hope so haha.Haha ok I understand completely now!
I have a good alignment shop I go to So i'm not worried about that lol
I'm defiantly interested though. Lets make this happen!!!
Count me in!
Unfortunately this will not address the wheels moving further back in the wheel well. We would need another adjustable arm, which would replace the trailing arm. Now, that being said, I could probably have that manufactured as well, but I'm not sure how it would affect anything else in the wheel well since nobody has done it yet.Thanks for posting this Kevin, good info & pics. “I may be interested, depending on price” – will be the most chosen option in typical 6GA fashion.
Couple questions…
1) The caster that comes into effect in the rear when really slamming these cars, will this address that? Or is that a whole other issue altogether. There have been discussions about that, but it always sounded like it required a crazy amount of custom machining and geometry.
2) I am also wondering, since I don’t do my own alignments, is your average shop like Tire Discounters going to be able to decipher all the aspects of these new arms and do a proper job still? Or would you have to instruct them as to how to work it. Sounds like a specialty shop might be needed.
3) How helpful would these be for someone like me with a somewhat milder drop, at 24.5” ground to fender? Sounds like they more geared toward serious stance.
count me in...
Maybe! I'd have to see the design of them and work with my buddy on it. Honestly any arm has a possibility of being replaced. It comes down to the money though. If you replaced every arm, it would be VERY expensive, and your alignment guy would hate your guts.Kevin you know I'm in.
I would be very interested.
Potentially, yes. I'm not sure if that's an option from the manufacturing plant though.Wouldn't it be more feasible to use an off the shelf poly urethane bushing insert and metal sleeve?
Keep me updated and I'll buy a pair as soon as their ready.
Reading comprehension has eluded Roy.u got all 4 for $85
everyone else gets a pair for $120?
Yeah, too much work for something like that. I can just imagine how horrible it would be to try and align that and see a jungle gym underneath each wheel well.xci.ed6 said:With all 5 arms adjustable, I think you could move the wheel forward, but I don't think you can do anything about the toe change, which get's fairly severe when the car is slammed, which has mostly to do with the angle of the arms, not the length, except modify the subframe-side mounting points. The real downer, it causes the outside wheel to toe-in during cornering, basically making the rear of the car steer itself towards the corner, contributing to understeer.
