thejameshimself
Re: My retrofit project
this is gonna be sweet
Getting the lines completely off the main part of the lens (high/low beam area) was NOT a problem. My issues was getting them off the edges of the lamps and close to the ripples in the corner lamp area. I managed to get them out of there but in the end I ended up sanding off a portion of the ripples which looked horrible afterward. Which once I done that I really had no choice but to remove the ripples themselves.like i said on AT, the headlight restore kit has that clearcoat polish on it that helps really well especially with this DIY, but they are $20 a set.... i used it on one side of my headlights... i will go and take pics but they are back on my car and its snowing bad this morning.. the i dunno what kind of plastic polish it is but its like a paint like clear coat
Well in the long run that is the plan. As for right now my only other option is to pull one of the lens from the OEM's that are currently on my car. Of course I won't do that till the time comes for lens.So Darryl, I assume your buying another lens for the headlight you were working on? Sorry to hear it was so difficult.
Well I only ruined one lens. So other than that the set of headlights are mint. As I stated above I have a set of OEM's on my car as well so if needed I will sacrifice one of those lens..Darryl, it's no knock against your work, but could you post a pic up of the work you did. Never know, someone may still pick that set of headlights up from you and be willing to finish what you started if they are still salvageable.
Hope you can get your hands on another mind set of OEM headlights for a good price.
