Please help with brake, and steering wheel issues
johnnxiv
Miami, FL
So when I first bought my accord 02, the brake was excellent, it slow down the car just like a brand new car's brake. My steering wheel spin was very smooth just like a brand new car.
After I bought it to a mechanic to do my timing belt and water pump, my brake become lose, it doesn't slow the car down as good as before, basically I have to press twice as hard to slow down at the same rate as I first I got the car. My steering wheel spin is much harder to spin than when I first got the car.
I checked the brake fluid and the steering wheel fluid, they are both at good level.
What can I do to improve my brake and steering wheel?
__________________
johnnxiv
Miami, FL
My brake pads are still very good, has the car for 2 months. My brake fluid is in good level.
When I turn my steering wheel, there is no sound, but today I feel that its
getting a little bit harder. It is much harder than 2 month ago.
Mile:90,9xx
After I get my car back from the auto mechanic, my Brake Lamp did turn on, I ask him he say one of my brake light is out which is extremely weird because my brakes lights were perfect fine before go to the shop. So I bought brake bulbs and install it and the Brake Lamp is gone.
An example from google
Igor
Under construction
Florida
You could have air in the system from when mechanic took it all apart to do the belt...bleed the brakes and see if that changes anything...good luck
johnnxiv
Miami, FL
I open the hood, and turn my steering wheel left and right. The steering pump connected to the engine does make little noise and it shake a little bit. Does this mean something wrong with the pump?
DarkSideAccord
nadeshiko fobz ftw..
timing belt and water pump has nothing to do with the braking system.... did the mechanic touch anything on the brake system?
