Please help with coilover sleeves! !
its_budddah
california
Hey guys ! well I'm struggling with these megan coilover sleeves! I know they are cheapmade but I tought I would give them a try. Well today I started doing the front and installed them on top of my monroes with the proper O rings. Then I notice all the things that came with the stock strut will not fit properly, so I decided to just install it with only the 2 stock bushings and the little tube that goes in the middle. This is the order I have them on strut. 1)aluminum sleeve 2) slevee ruber isolator 3)spring 4)ruber isolator 5) Plastic Top mount 6)bushing 7)metal tube 8)stock top plate 9)bushing 10)washer 11)nut.
Okay now there are two. Problem one is I heard a noice and looked at the spring and I saw the plastic top mount go from the top, through about two rings down. What should I do? I have the sleeves -1.8 on some monroe shocks . Second problem is I noticed the bushing was sticking up way too much up. Any Suggestions or corrections would be REALLY appreciated! ! THANKS
http://i213.photobucket.com/albums/cc262/joshhg93/Mobile Uploads/2014-01-10-19-31-58_zpse42f5cde.jpg
http://i213.photobucket.com/albums/cc262/joshhg93/Mobile Uploads/CAM01571_zps05f51fca.jpg
