Hoff Daddy
So, I drive a 99 4dr LX f23a1 accord with a rear disk brake swap. That is the only thing I've ever done to my brakes and all that seems solid, my car stops pretty good, very smooth. What is scaring me is that even before my disk brake swap, my pedal feels solid as a rock in the cold. The fluid is full now, I've never had to add and it was flushed 10000mi ago for a front brake job and very recently for my disk brake swap. I've talked to a professional and he said that sounded pretty bazaar. I suspect it's the 3 old rubber brake lines being bad and contracting in the cold or something like that. The other problem is pretty recent... I found it out sliding backwards on my steep driveway on ice and I locked the brakes and spun myself around instead of sliding back into a tree. My brake pedal will start to hiss if you give it a lot of force and once it starts to hiss you could probably just push it straight to the floor. The car has no braking problems in normal weather under normal circumstances.
