power locks won't work
malsr
portland, or
My power locks are not actuating. Power locks fuse is good. The switches will not move the locks up or down. If it was one lock not working I would say its an actuator. However, all 4 locks are not responding at all. Is there some kind of a master actuator somewhere?
98, lx, 4dr, 2.3
malsr
portland, or
I'll try it tomorrow and report back. Why the 5 minutes...I've heard that elsewhere as well??
based in: not shared
front of the dash, at the bottom, and in the center. the ecu fuse needs to be held out for a while so that the ecu completely loses all its info. you could also just unhook the negative battery cable for about the same amount of time.
the edit button is located in the lower right, too. next to quote.
