AccordFlex
Ok, so a friend and myself decided to install the vtec light. One in my accord, one in his EJ8. Neither of them worked...
When I turn the ignition to the second position, the light will stay on, but as soon as I turn over the engine and try to test it out, it will not come on. My car does need an oil change, and I have heard that vtec wont kick in when you are somewhat low on oil so could that maybe be my problem?
I tied the wire into the green with yellow ECU vtec wire so im not sure what in the world I did wrong. His, we think just has a bad ground because it wont come on at all, when he grounded it to a bolt, he tightened it too much and broke the wire so we are going to try it again another time with his.
Anyone have any suggestions. Car is F32A4 by the way. I could see a yellow with green wire either... there was none there like the DIY says there should be.
