Finally making use of this section with a noob question. Last time I had the rear pads/rotors changed I had a shop do it because I had to replace the rear calipers themselves and it was right after I got the car so it wasn't something I was ready to mess with yet. So I've changed front brakes but never rear.
How do you guys compress the rear caliper piston? My c-clamp I used for the front is like 1/8" too small and there seems to be nowhere else to put the other end of the clamp to compress the piston in. I tried the little ledge by the brake line bolt (which put the clamp at a slight angle) and when it got tight I used a pipe for leverage, and ended up bending the slide handle on the c-clamp.
Not sure I want to go buy a bigger c-clamp. Is the rear piston suppose to be much harder to compress than the front? I have the brake fluid reservoir cap off...
EDIT: Does the piston have to be screwed in, as in turn it with something using the flat indentation in the top of the piston? I never turned the fronts, they just compressed in...
