knighthawk1104
but he says when he accelerates, not at any specific speed.
Sorry I am exhausted, I just re read his original post. I was looking around and saw that this can happen with a bad U-joint in the driveshaft and what I do know is that the joints don't have to show visual signs of wear and tear in order to be bad due to the grease in the joints being gone or warn out.
I pretty much read a couple peoples posts where they have the same symptoms as what you are describing almost to a T.
I thought all driveshafts had a Universal joint? Honestly I'm at the point where I'm just trying to throw up different ideas.
Alright hmm.
Do you have access to a lift where you can easily examine all of this easily?
Testing Bearings
To determine if your bearings are bad, use a floor jack to lift the vehicle, and place it securely on jack stands. Place your hands at nine and three o'clock on the tire and attempt to rock it back and forth. If the wheel and tire move at all, you could have a bad wheel bearing. It is also important to periodically inspect the bearings, the bearing races and the hub. The bearing and races should be smooth and free of scratches and be lubricated with plenty of wheel bearing grease.
