the OFFICIAL G23 swap parts list
DarkSideAccord
nadeshiko fobz ftw..
Here's my G23 parts list for all u guys who want to do the head swap.... keep in mind that u can upgrade any of the components if you want, such as cams, pulleys, etc
1. H23 full head
2. H23 IM
3. F22a coolant pipe
4. H series PS bracket
5. P06 or P28 ECU... for p28, u need to turn off the vtec
6. OBD2 to OBD1 conversion harness
7. H23 timing components
8. F23/H23 tensioner - needs to be modified to minimize the slack on the timing belt
9. H23 timing belt cover - both upper and lower cover
10. H23 header
11. some timing belt tht's exactly like the GSR belt, but thinner
12. H23 thermostat housing
13. H23 fuel rail
14. OBD1 H22 fuel injectors
15. H23 dizzy
You'll use these part from the f23:
1. F23 alternator and alternator bracket (need to shave off a bit of the bracket to make it fit)
2. F23 PS pump + a couple spacers when mounted to the bracket
3. F23 TB (only if you want to reuse the F23 intake)
4. F23 water pump
5. F23 head gasket
write-up by pirateMcFred for those wants to read it....
http://www.honda-tech.com/zerothread?id=1046336
