I plan to install a Magnefine filter. Looking down at the trans from under the hood, there are two horizontal, parallel lines coming out the tranny. The bottom line goes into the radiator and I presume is the exit line from the tranny, correct? In other words, fluid flow is counterclockwise through these lines?
I would think this is the best place to install the filter, as you want the hot oil filtered for better efficiency. Plus it's easy to change the filter as it's just behind the right radiator fan.
