Okay, so I changed my passenger side axle about 3 weeks ago and that’s when I started leaking. I then had the seal replaced with a not-so-new one, but it was still in good condition, and the leak persisted. What could be the causes of this? The leak is dripping off of the base of the axle (the part that connects to the tranny.) What could be possible causes? Improperly seated axle? Bad axle seal? Bad c-clip on the end of the axle?
I leak about 1/8th of a cup over an 8 hour period. It's not really a puddle however, just looks like the oil is spread out on the floor. How would I check and see if the axle is properly seated?
I've never been a believer of additives, but I'm really close to trying the lucas transmission fluid substitute that is supposed to stop leaks and what not .. I'm assuming it's going to swell the seals ..
OH also, I had an auto, and did a 5 speed swap, so now it's got a 5 speed in it. However, I'm sure that the passenger side axles are the same .. right ? What if the mechanic used an f22 tranny .. ? Would the passenger side axle still be the same ? What if that's the issue ? How do I find out what kind of tranny it is ?
