Jun 8, 2010 #11 S supasnipa360 Member Joined Mar 29, 2010 Posts 18 Reaction score 0 Location Erie, PA ^ thats a big facepalm.
Jun 8, 2010 #12 I ilovevtec951 Well-Known Member Joined Dec 18, 2008 Posts 78 Reaction score 0 Location Riverside Ca (951) they sale gasket remover in a can if the razor blade doesnt work but it should do the trick
Jun 8, 2010 #13 finch13 Well-Known Member Joined Apr 2, 2008 Posts 5,025 Reaction score 41 Location Twin Cities, MN Is the gasket stuck to the cylinder head or the valve cover? Head, use a razor blade or gasket scraper, that caustic spray on gasket remover won't work here. Valve cover, pry it out until you can grab it and just yank.
Jun 9, 2010 #14 HondaLuver83 Well-Known Member Joined Oct 22, 2008 Posts 5,000 Reaction score 25 Location Oregon I used gasket sealent instead of buying a new valve cover gasket. I had a tube sitting around so why not. Its worked fine for almost 2 years...
Jun 9, 2010 #15 S Steverino Well-Known Member Joined May 4, 2007 Posts 200 Reaction score 1 Location Near Toronto, Canada Isn't the gasket a rubber piece that you can just peel away? . . .
Jun 10, 2010 #16 D DoWorkSon4521 Member Joined May 4, 2010 Posts 20 Reaction score 0 Location Tulsa Ok It is the rubber peice but mine was glued....I got it off with a razor blade, flathead, and a bunch of other tools my friend had laying around and it took about 2 hours and it sucked!! Last edited: Jun 10, 2010
