IR II IC IK
so i've had this issue for awhile and its a whine that increases with rpm's. yesterday my timing belt was due so we replaced the timing belt and balance shaft belt, water pump and both tensioners and started it up without the alternator or power steering pump and it still whines. although it definitely sounds different. i can figure out whats wrong cause i originally thought it could be the water pump bearing or the tensioners but i guess i was wrong. and its just an annoying high pitched noise that i was gone.
