02 Av6 Air problem
Goldnight02
I have a 02 Av6 with 88,000 on it... Today I turn on my Air and it will not come on.. It's not blowing nothing out... What could be the problem. please help me. Have anybody have this problem before ????
blacknight
Superman, uh mod
Bergen County, NJ
IS th blower not coming on, or that air isn't getting cold.
If it's the blower, check the AC clutch fuse/relay and make sure it's ok. It's in the fusebox under the hood.
If it's not getting cold, just recharge the system
Goldnight02
Thanks Man!!!
Did you have the Same problem on your Car... It just not blowing air... Only if you put it on high,,,, But its blow hot air...
blacknight
Superman, uh mod
Bergen County, NJ
Nah, mine is ok.
Check the fuses under the hood for the AC clutch.
Or, pull out the center peice (That goes around the radio) and check the connections for the fan speed
Goldnight02
Went too the Honda Dealer... They had too do a Test on the car. It cost me 85.00!!!
To find out that the AC clutch went out...... The shop guy said that the Filter on the Air system never was change. So they had to put a new A/c Clutch on it... Plus it wasn't cover on the car.. Because I went over the 36,000 mile... That sucks...
