Roboytoe
hello i bought my 98 honda accord ex 2.3L coupe about a month in a half ago. I recently took it to auto zone to get the error codes because i was in the process of repairing it.
Error Codes:
Replace Engine Control Module (ECM)
Definition - Code P1164 indicates the PCM detected the heated oxygen sensor 1 signal did not switch (remained? lean?) for a predetermined period of time.
P1166 - Lean A/F-11 (Bank 1 Sensor 1) Heater Circuit Malfunction.
P1167 - same as first code
P0141 - Ho2s-12 (Bank 1 Sensor 2) Heater Circuit Malfunction
P0700 - Automatic Trans axle Malfunction
P1738 - A/T (TCM) 2nd pressure Switch Circuit Malfunction
P1456 - EVAP System Leak Detected (Fuel Tank Area)
So after i got the codes i did research on the ECM because well a new one is very expensive, and then i would have to get the ECM programmed at a honda dealership which is also expensive. Some people say its not really the ECM because it rarely goes bad so it might be the o2 sensor, im not sure tho.
But yesterday i tried to turn the car on after not being on for maybe a day or two. i recently changed the battery but the weird thing is that it has absolutely NO POWER. what i mean is that when i put my key in the ignition the green key in the dash doesn't turn on, nothing turns on it doesn't crank, no lights in the dash, radio off, clock off, nothing works! Im truly baffled idk what to do i love this car because its my first car. I would love to here some feedback from anyone on what i should do or check. If worse comes to worse and i have to sell the car because of cost of repair, i will sadly do so
Error Codes:
