A/C Doesnt work..what possible problems?
99cfENVYv6
hmmm, i have a Chilton manual...ill see what it says in there...For some reason, i didnt even think about my manual, haha
and_one
i found my clutch was burnt because i just looked straight down at the compressor from the right side and went and grabbed the side where the clutch is located on the compressor...and just burnt chips of the clutch fell off...also i think you might be able to see it the clutch with a flashlight...sorry if that was confusing but thats my best way to explain it
**** forgot you have a v6...but try looking for it and feeling it...youll feeel chips of the burnt clutch
99cfENVYv6
Well sounds like Ill be checking the compressor tomorrow. Maybe thats the problem.
Dinzdale40
Large Member
Chattanooga, TN
mine went out for a month last year....then i found a plug that was undone and it worked...i think it was on the condensor...
jccg5
no ac=no spending money
no ac=no hard time
no ac=happy ness
no ac=make gurl sweat..
Tx_Accord98
MikeyMike said:
thats what i think it is, i havnt had AC since my wreck, recharged the system 2xs, it still holds pressure and everything. just blows warm ait @ 60º on the dial ( i have auto).
mine is either the compressor or i have a wire shorted out somewhere that I didnt pick up on, with my rebuild. im bringing it to an electrician soon since it started to get warm.
just because you charge it 2x, doesn't mean a thing if the compressor isn't turning. you will only be able to charge if the compressor is engaging. you can jump your pressure switch to see if your compressor works. if you don't have a charge at all, then your compressor won't work. you have to put the system into a vacuum then charge the system to get it to work effeciently.
