2002CG3coupe
Well guys, recently my brake lines exploded on me a few days ago.....FML
.....lucky me the issue happened in my garage. But before I had the issue with my brake lines, I notice that I would have air come out (not sure where) and my idle would act a little strange (fluctuate 750- 1000 rpm when pressing throttle then return to normal idle after applying the brake). Researching here on 6GA, its possible that I might have a faulty abs module which could have cause the leak. I so naturally I thought, 'change the line, replace the module, and check for any potential vacuum leaks.'
Then this question crossed my mind, 'is it possible to delete my abs module?' I know the whole point of abs is to assist in braking in dangerous conditions. For instance, in wet weather condition it prevent the wheels from locking up. But I'm not too concern with that, I've driven vehicles without abs in wet/snow or dry weather conditions and was able to drive it as a normal vehicle, even at times it required me to slam on the brakes.
To get to my point, I was curious has anyone attempted this idea or thought of it as well, if so what are your pro and con about this change in the 6GA. From what I gathered so far the only trims that came Non-ABS were the manual LX and DX trims for the Accord. So for the manual LX and DX drivers I definitely would like to know your opinion as well behind the wheel of the Accord with ABS.
