jdmgear
- Joined
- Sep 8, 2005
- Posts
- 258
- Reaction score
- 0
Jesus that looks amazing...how did you even make the tail light cover like that? prefab or did you make it yourself?
__________________
I actually found and bought a pair of old school clear taillights and painted the top red with Vans Red taillight spray. I wanted to go with a more unique look rather than the clear on top and red on bottom.
Any updates? I saw you had this on HIDplanet and I read it a few weeks ago. I haven't checked it recently though.
Ryon
I have installed my the LEDs on the top part (outer taillight and inner trunk taillight) to run the constent on. On the factory accords as you know the bottom part taillight is usually the constent on. As for the area that is clear I am going to install a modded SRX Shroud with the remaining LEDs on the bottom that will be only used when the turn signal is on. If you have ever seen an SRX taillight all the LEDs illuminate when the turn signal is on. So this means that the outer top and bottom portion(clear section) of the Taillight will illuminate along with the inner (trunk taillight) top portion. I've just been so busy that I have not had that much time to work on this project along with my headlight project that was switched to S2K projectors.
The biggest pain is that I had to cut all the LEDs from the original metal and solder them back so they would fit in the upper portions of the taillights.
