BG 44k question on its uses...
001Stunna
Toronto, ON CANADA
Well i had the chance to pick up 3 cans of the stuff for about $25 so i said why not. The kit comes with a...
-throttle body and intake cleaner
-in gas cleaner (to pour in gas tank)
-fuel injection system cleaner
The first two are pretty easy to understand on their uses. The third has got me pondering a tad. If anyone has used the last one before...is it pretty much a cleaner then you hook up to the fuel line and run the car off of it? or a cleaner used somewhat like seafoam through a vacuum line?
Pics of all 3 cans
Mikey
Middle America
I work at a GM dealership and we use it all the time. I threw a can of the 44K in my tank and I didnt really notice anything. Probably not seeing as how I didnt do the full treatment.
If you're asking about compatability with our Hondas, I dont see any reason why you cant use it. If you're asking opinions or if anyone's used it, well, there ya go. Since I work there, if/when I do a fuel-induction service, I'll more thank likely use the BG stuff.
001Stunna
Toronto, ON CANADA
Levin, I can't post youtube vid links here at work, but near the middle of the page, might be helpful.
http://www.google.ca/search?q=http:...0&bih=868&bav=on.2,or.r_gc.r_pw.,cf.osb&cad=b
Derek, thanks for the video. I was hoping it wouldn't be the case of where the engine has to run on it but it seems it is. Off to partsource tomorrow to see if they have the tool required on the lend-a-tool program.
I tried to be as clear as i could in the first post regarding my question but i guess not...
The kit comes with 3 cans/bottles. I understand one is to be used as an in-tank additive and one can/is to be used to clean out the throttle body.
What im wondering about is the third can...and whether its used through a vacuum hose (ie. like seafoam) or needs to be connected to the fuel test port, unhook the pump, pressurized as needed to match the fuel pump pressure and run the engine on the cleaner???
