Blower motor problem
kem
new york
Hey 6GA , I noticed the other day that my fan control is only working on 3 and 4. I have checked all the fuses and everything was fine. Anything i can do to fix this? Thanks in advance
RichBinAZ
Mesa
If that doesn't work, check all the connections into and out of that multiplex unit you just changed out.
If it was working before and now it isn't...
LX_F23A1
Chicago
Grab a multi meter and check for continuity in every wire thats in the connector for the blower motor switch
UTIaccord
Texas
this^^^
make sure u do that with the car off (incase u wanted the ohm reading to)
check continuity between fan speed 1 & power (then ground incase its ground side controlled not sure if our blowers are power or ground side controlled) and do the same for fan speed 2, but yeah the resistor is a prime culperate as well
