Brake Upgrade Options
SoCalAccord2000
San Diego
i have the GS upgrade bolt on, i could tell the difference in stopping power compared to stock v6. for RL/TL you need richies bracket or custom ones like redryder said
SykVSyx
Tee Dot Ohh
I forgot about this thread, I did update the info about the brackets for the RL calipers and the Honda Pilot rear rotors.
I need to get the complete info for the 350Z rotors(Brembo), as those are what go with the RL caliper upgrade.
Same with the Pilot rear rotors.
Anewosis
Tampa
I was just doing a little bit of research about the 1999 cl v6 brakes and I think it is a go.
accord 4cyl front brakes.
Part Number: 31243
Weight: 10.6 lbs
Warranty: 2 YR
Notes: Rotor onlyRecommend replacement in pairs.
Bolt Pattern Diameter (mm): 114.3
Drilled: No
Lug Stud / Bolt Count: 4
Package Quantity: 1
Primary Bolt Pattern: 4x114.3 / 4x4.5
Rotor Bore Diameter (mm): 64.2
Rotor Directional Format: Non-Directional
Rotor Discard Thickness (mm): 21.0
Rotor Initial Thickness (mm): 23.1
Rotor Material: Iron Alloy
Rotor Outside Diameter (mm): 260
Rotor Overall Depth (mm): 47
1999 acura cl v6 front brakes
Part Number: 31248
Weight: 13.01 lbs
Warranty: 2 YR
Drilled: No
Package Quantity: 1
Rotor Initial Thickness (mm): 23.0
Rotor Outside Diameter (mm): 282
Anewosis
Tampa
Well just so you guys know I did the cl rotor upgrade with the Honda accord v6 caliper brackets or 98-99 Cl v6 brackets and Odyssey calipers. It all fits nicely in the stock 15in wheels. The car stops very fast and smooth. No fade whatsoever. I would definitely recommend a wheel and tire upgrade to match the braking power. Only modification is to bend the dust cover a little to clear the caliper bracket.
REPSOL
Downey, CA
any one know if the 99-00 TL Brakes would work? went to the local Pick a part and found a couple of them I can yank parts off of. but there was no accord to match it up to. :(
DarkSideAccord
nadeshiko fobz ftw..
i have the acura legend GS setup for sale :)
i'm local too
