Since the last week my car would randomly make a squealing sound when I'm driving. It would stop when I brake. It MAY change it's tone when I am applying the brakes but I am not sure. What can this problem be?
You wanna get on that problem pretty quick. Normally when your brakes wear the metal indicator will scratch against the rotor when you apply the brakes and make a squeeling sound. When you're not presssing the brakes tho, there will be no sound.
Whats happened in your case however, is that the pad has worn down so much that metal has become exposed and is randomly grinding into your rotor when you're driving, this is no longer the indicator, you've gone well beyond that point. Also this is the reason why the sound is different/doesn't happen when you do brake. The same thing happened to me, just make sure you change em pretty soon so you avoid damage to the rotors.
