timoteo
F23a1 motor. Took off the head, cleaned everything, replaced head gasket and head bolts, reassembled everything, got down to adjusting the valves and i cant for some reason. If you are looking at the motor while its at tdc the right intake valve on every cylinder doesnt loosen ever. I spun the motor counter clockwise looking to see if the valves would ever become loose but they dont. This is my first time taking the head off my car so I am sure i simply did something wrong, however, I have not been able to find anything explaining why this is happening. I did this to learn more about my motor and cars in general and while I learned quite a bit it seems I bit off more then I can chew because I cannot solve this puzzle. If someone could explain any possiblity as to why this may be happening I would be very appreciative. Thank you for your time
