OK so I just recently bough a 98 accord in good condition. All is running fine and I decide to replace the radiator hoses and water pump and timing belt for maintenance. Well since then the car likes to overheat very easily. If I turn the AC on the over heating doesn't happen. It appears that since changing everything the radiator fans aren't turning on when the car gets hot so thats why turning the AC on seems to help since it turns the radiator fans on. Any suggestions? I tried the coolant bleed screw by the thermostat and only antifreeze came out. I have tried replacing the coolant fan switch on the thermostat housing, replacing the temperature gauge sending unit in the head and replacing the other temperature sensor in the head also. Oil looks perfect, car drives fine. Ideas?
