Jul 7, 2014 #1 M mello_jdm Member Joined Jul 7, 2014 Posts 24 Reaction score 0 Location Brooklyn Hi everyone my check engine turn on and the code given is P1457. I research and I found out it could be the gas cap but my is in good shape. Also I found it could be a ring in the gas tube. Can anyone help me out with this.
Jul 7, 2014 #2 xci.ed6 Well-Known Member Joined Sep 5, 2007 Posts 2,909 Reaction score 9 Location Tampa Bay leak finding tester you put in a couple psi, regulated, (through cap) and block hoses. When the pressure rises you blocked the hose leading too the leak. on v-dubs usually purge solenoid, idk Honda's, mine still works
