Gil'sCG6
i know these are very common in going bad on 6th gens, my front and rear defrost button bulbs were extremely dim and i could barely tell if i actually had the defrost on considering the bulbs were so dim so i proceeded to replace them with new bulbs. the process was simple and took me about 10 minutes but then after i replaced the bulbs before i re-installed the climate control i tested out the bulbs and the defrost bulbs work exactly the same they are extremely dim even with the new bulbs.... what could i have done wrong? (test was done with all connectors plugged into climate control and ignition on obviously)
