How would i go about changing the wire harness that connects to the primary o2 sensor? CEL still on after i changed the o2 sensor.. I would cut my harness but dont know how far i would have to cut... any help?
There's no need to cut the other side of the harness unless you can see that it's damaged, deteriorated insulation, etc. What sensor did you replace it with?
only if there was any sign of damage.. or corrosion.. or anything of that matter.. insulation is still good.. bending the harness here and there to feel for a weak wire and nothing pops up.. checked with ohm meter on the sensor and harness, i know it's not such a big deal.. but gas is kind of a big deal also..
