Fast Blink Right Turn Signal
lothian
NC
2000 Accord LX
131k
The right turn signal is suddenly fast-flashing relative to the left turn signal. All ride-side bulbs light; and neither the dash indicator nor the corner bulbs were changed. Presumably, just one relay device drives both sides so given the fact that the left turn signal operates fine, I assume that this part is OK. This phenomenon just started.
What's the deal? Is this a code/indication of some thing?
SupraGuy
Edmonton, Alberta, Canada
That is generally an indication that a light bulb has burned out.
Try turning on the hazard lights, and comparing left and right sides, you'll probably find that a bulb has burned out somewhere.
Edit: This will also often happen when a bulb has been replaced with an LED alternative.
The flasher operates on a Resistance/Capacitance timer, increasing resistance on the circuit decreases the amount of time that a flash takes to cycle. In this way, it can warn you of a failed lamp. LED lamps use a lot less power, so they restrict current with a high resistance, which the flasher will treat the same way as a failed lamp.
Accordx
Washington, USA
As SupraGuy already said, the bulb is either burnt out or close to it, I've seen other people on the road who have a fast blinker so it may not be burnt out yet
'Tis I
it has happened to me before when the filament in the bulb was broken, but still connecting over the broken spot. that would cause a variance in the voltage through the bulb, thus triggering the hyper flash for a bulb outage.
cars run separate left/right relays for exactly this reason, to let you know you have a bulb out.
