Is anyone a pro at doing coolant flushes?
Cause... There's no bleeder on these motors and I have no idea how to push air pockets out...
With the car cold and parked, open the radiator cap and fill the rad to the top. Do the same with the overflow bottle and fill it to the max line. Leave the rad cap off.
-Start the car and let it idle
-Turn the heater dial to HOT and turn the Fan off.
-Watch the coolant level on the rad neck and top off if it moves down at all.
-If you see air bubbles don't worry
-If you see the level rise a tad and spill out a bit don't worry(just clean it with water when you're done)
-Increase the idle to about 1500-2000rpm and keep it there(either have someone step on the pedal or stick a screwdriver/locking plier to hold the thorttle cable just a tad.
-Give both lower/upper hoses a squeeze frequently as the car is running
-Allow the car to run until no bubbles show and both radiator fans come on(should take about 10mins)
-Keep the rad topped up full ALL TIMES
-Once both fans come on put the rad cap back on and clean any spills with adequate amount of water. Especially if pets/animals live around.
*You can also take the cap off if the car is hot and turned off, BUT use a large enough towel to grab the cap as it WILL spew out coolant as it is under about 15psi pressure. The towel will catch the coolant and not your face/hand this way. Only do this if you know you can handle a hot towel/coolant on your hand(s)
