bigmoe88
Check your ground wire, I had the same problem, tried with a different relay and got the same buzzing. I looked at the ground wire and it was still on, but it wasn't tight cuz I can wiggle it around between the bolt and the body of the car. I had to tighten the bolt up and now it works fine
BTW this happened on my 6th gen AV6 w/OEM foglights like a month ago.
Hope this helps!
Hope this helps!
