Kyleelder
I searched and couldn't find much info but basically my car is sitting slightly above 190k. At around 160k it was lowered on Eibach Sportlines and KYB GR2 struts with a wicked tuning rear camber kit. Now my car is starting to make a weird clunk sound at low speeds, parking lots, small bumps and when you let the clutch out sometimes(it sounds like its coming from the lower front right).My car also feels a bit wobbly. I suspect my suspension is just getting wore out.I can't see any torn ball joints or anything. and i read a few things on the web about checking ball joints and tierods but kind of didn't understand. Does anyone have a DIY for checking out suspension components? Like I grabbed my wheel at 3 and 9 0clock position and pushed left to right the wheel did move, but it felt more like it was hitting the steering lock on each side than play in the suspension. I also get a humming sound occasionally that I think may be a wheel bearing, but can't figure out which one.
Some part of me wants to just replace everything.Ball joints,tie rod ends, wheel bearings. I found this on ebay Full Front Suspension Kit however I'm not to sure of the quality of those parts. What parts are recommended from someone who has done this before?
