Help Installing Eclipse avn5510
jasonjs
SoCal LA
Can some one tell me install a nav system in my 98accord 4cyl ex ..i got the main power/ground/remote hooked on need help with the speed pulse signal and the reverse signal wire..and is there anyway to bypass ..the whole brake engaged to watch a movie ? i read u could only watch movies when the brake is engaged ..thanks
BadgerType
Resident ***hole
SW FLA
my pioneer allows you to watch movies even with the parking brake wire not connected
dustint209
Lafayette
I know on my deck there is a brown wire that is meant to hook up to the shifter to only allow video when in park. I simply grounded the wire and it overrides the safety feature. Hope this helps.
hancockd
SLO CG2
Orlando, FL
Should just need to ground the parking brake wire... that's what I had to do on my AVN5435
hancockd
SLO CG2
Orlando, FL
For the reverse wire I just ended up running it all the way to my reverse lights...
VSS... looked at the Haynes manual real fast...easiest way would be to pull the instrument cluster out and tap into the BLUE/WHITE wire on the harness that plugs into the cluster.
Maybe this thread will help you as well.. http://www.honda-tech.com/showthread.php?t=2520479
