Hid Help!!!!!!
nhsrunner
[Okay that's just not even right...]
Umm not sure what part you didn't get but let me try and make it more simple for you. The ballast converts your cars 12 volt battery's charge which is DC into about 23,000 volts of an AC. The reason you need all of this power is to ignite the xenon and other gasses inside the HID bulb. As far as the wireing goes, it's a simple circuit with the battery's enegry going into the ballast, then being converted into AC, then to the lights, and then back to the ballast and finally then to the battery. So like I said before, the bulb is only directly connected to the ballast.
scrappys64
MD
Oh no that part wasn't entended for you.... I got that part it's just that right at the bulb it's got another set of wires I just need to know where those go thanx!!!!! :thumbsup:
nhsrunner
Ahh gotcha lol not sure then what the other wires are for.
shavedaccord
Gates, OR
First off what brand of kit is this so we know if we're dealing with a plug and play or one that requires a harness/splicing? If this isn't plug and play without pictures my best guess would be the 2 extra wires is your hot & ground that need to splice into the OEM headlamp harness.
scrappys64
MD
It is a plug and play that I got from Enduromotorsprts CA... The brand they said it was is e-motor. The box is green I will have to try and get some pics for you guys tonight... It is an H7 bulb type just to explain it in a little more detail. Right next to the bulb in the same gasket there are two wires, the diagram does show them + & - but they don't say anything about splicing or anything on the other end is a male connector that looks like it goes into the stock plug. I can't contact Enduro cause they are all at SEMA this week. Any help would be greatly appreciated thanks Fellas... :D
